Honda fes 250 foresight
Honda fes 250 CC
All the features that a scooter should have were in the Honda FES 250 Foresight, a slightly old but known model, a model planned with low fuel consumption.
Reliable, durable Foresight was also a very important model in terms of its ergonomic structure, wind blocker feature and fuel pint. You can look at it with the eyes of your greatest queen in both individual and commercial use. When I returned the Honda FES 250 Foresight, which I borrowed from a close friend for a week-long trip, my feet were almost backed up. Finally I found a clean fez 250 cc. I have been using it for about 6 months, an inexpensive engine works a bit noisy because it has only a carburetor engine. 2 people can travel very comfortably in urban traffic. It has a strong pulling power thanks to its 250 cc engine. I made my first long journey between Istanbul and bolu Vengen. We easily went to the warehouse for 330 km. its tank fills up to 10 liters
Technicial Specifications
Engine Liquid-cooled 4-stroke, OHC single cylinder
Engine volume (cc) 249.4
Cylinder diameter & stroke (mm) 72.7x60
Compression ratio 10.5: 1
Fuel system 30mm CV type carburetor
Max power (hp @ rpm) 19.2 hp / 7000rpm
Max torque (Nm @ rpm) 21 Nm / 5500rpm
Ignition Electronic
Starting Electric
Gearbox V-matic
Dimensions (LxWxH) (mm) 2070x735x1425
Distance between wheels (mm) 1450
Seat height (mm) 745
Clearance (mm) 140
Fuel capacity (liters) 12
Wheels
5-arm aluminum casting with front / rear U profile
Tires Front 110/90 - 12 64 L
Rear 130/70 - 12 62 L
Suspension Front 33mm telescopic fork, 88.7mm flex range
Rear Single shock absorber rear fork, 96.2 mm flex gap
Brakes Front Combined 240mm disc with 3-piston caliper,
Rear Single-piston 220mm hydraulic disc with caliper
Weight 158.9 kg
Color options Silver, Black, Blue |
